Ana içeriğe geç
Philips DVP5992-F7 USB port Replacement
Neye ihtiyacın var
  1. Philips DVP5992-F7 USB port Replacement, USB port: adım 1, 3 resimden 1. Philips DVP5992-F7 USB port Replacement, USB port: adım 1, 3 resimden 2. Philips DVP5992-F7 USB port Replacement, USB port: adım 1, 3 resimden 3.
    • Remove the three 6.4 mm Phillips #1 screws on the back of the device with a Phillips head screwdriver.
    • Remove the 6.4 mm Phillips #1 screws on each side of the device.
  2. Philips DVP5992-F7 USB port Replacement: adım 2, 2 resimden 1. Philips DVP5992-F7 USB port Replacement: adım 2, 2 resimden 2.
    • Remove the top plate of the DVD by firmly grasping the player on both sides.
    • Shift the top plate towards the backside of the player.
    • Lift the back half of the top plate up to remove it from the player.
  3. Philips DVP5992-F7 USB port Replacement: adım 3, 3 resimden 1. Philips DVP5992-F7 USB port Replacement: adım 3, 3 resimden 2. Philips DVP5992-F7 USB port Replacement: adım 3, 3 resimden 3.
    • Locate the bundled cable connectors that attaches the USB port to the motherboard.
    • Firmly grasp the bundled cable connector and lift it from the motherboard.
  4. Philips DVP5992-F7 USB port Replacement: adım 4, 2 resimden 1. Philips DVP5992-F7 USB port Replacement: adım 4, 2 resimden 2.
    • Locate the area behind the USB port within the interior of the DVD Player.
    • Unscrew the two 6.35 mm Phillips #1 screws located behind the USB port.
  5. Philips DVP5992-F7 USB port Replacement: adım 5, 2 resimden 1. Philips DVP5992-F7 USB port Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to press down on the brass clip that holds the USB port in place.
    • Pull back the USB Port to remove it from the DVD player.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 532
