Ana içeriğe geç
Philips DVP642 Disc Tray Replacement
Neye ihtiyacın var
  1. Philips DVP642 Disc Tray Replacement, Top Panel: adım 1, 2 resimden 1. Philips DVP642 Disc Tray Replacement, Top Panel: adım 1, 2 resimden 2.
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
    FixBot'a Sor
    Yorum Ekle
  2. Philips DVP642 Disc Tray Replacement: adım 2, 2 resimden 1. Philips DVP642 Disc Tray Replacement: adım 2, 2 resimden 2.
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Philips DVP642 Disc Tray Replacement, Disc Tray: adım 3, 2 resimden 1. Philips DVP642 Disc Tray Replacement, Disc Tray: adım 3, 2 resimden 2.
    • Remove two 7.5 mm screws, one on each side of the player.
    • Remove three 7.5mm screws from the bottom of the player.
    • Note that the three screws from the bottom are slightly different screws.
    FixBot'a Sor
    Yorum Ekle
  4. Philips DVP642 Disc Tray Replacement: adım 4, 1 resimden 1.
    • Detach all the ribbon wires (4) attached to the motherboard
    FixBot'a Sor
    Yorum Ekle
  5. Philips DVP642 Disc Tray Replacement: adım 5, 3 resimden 1. Philips DVP642 Disc Tray Replacement: adım 5, 3 resimden 2. Philips DVP642 Disc Tray Replacement: adım 5, 3 resimden 3.
    • The first 3 ribbon wires can be removed by grasping near the head and gently pulling up.
    • Locate the skinny fourth ribbon wire near the top right of the motherboard.
    • Remove the fourth ribbon wire by grasping both sides of the black clip and pulling up. When reinserting, pull the black clip up, insert the ribbon ribbon, and push the black clip back down.
    • Be firm, but gentle when pulling to avoid pulling the wires off the head.
    FixBot'a Sor
    Yorum Ekle
  6. Philips DVP642 Disc Tray Replacement: adım 6, 1 resimden 1.
    • Now remove the remaining three 7.5 mm Phillips screws that hold the disc tray to the body.
    • Remove the 12 mm Phillips screw that secures the tray to the upright metal frame.
    • Remove the two 7.5 mm Phillips screws that attach the disc tray to the motherboard and front panel.
    FixBot'a Sor
    Yorum Ekle
  7. Philips DVP642 Disc Tray Replacement: adım 7, 1 resimden 1.
    • Gently pull forward and upward to free disc tray.
    FixBot'a Sor
    Yorum Ekle
  8. Philips DVP642 Disc Tray Replacement: adım 8, 1 resimden 1.
    • Tilt the tray sideways and then pull back gently to separate the tray from the front panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Toby Goldsteinholm
372 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G20
4 Üyeler
9 adet Kılavuz yazıldı
3Kılavuz Yorumları
If you work at it, inserting a small screwdriver at appropriate places, you can get the drawer front off (do this with drawer open). This is easier than removing the front panel from the player.
Steve Emerson - Yanıt Paylaş
I failed huhuhu
Hello kitty - Yanıt Paylaş
not useful without source for parts. i believe the dvd drive is a sony oem.
mapatouli - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 62
Her zaman: 10,073
