Ana içeriğe geç
Philips DVP642 Power Supply Replacement
Neye ihtiyacın var
  1. Philips DVP642 Power Supply Replacement, Top Panel: adım 1, 2 resimden 1. Philips DVP642 Power Supply Replacement, Top Panel: adım 1, 2 resimden 2.
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
    FixBot'a Sor
  2. Philips DVP642 Power Supply Replacement: adım 2, 2 resimden 1. Philips DVP642 Power Supply Replacement: adım 2, 2 resimden 2.
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
    FixBot'a Sor
  3. Philips DVP642 Power Supply Replacement, Power Supply: adım 3, 2 resimden 1. Philips DVP642 Power Supply Replacement, Power Supply: adım 3, 2 resimden 2.
    • Slide the power cord out from the case.
    • Be sure not to lose the rubber clip that is wrapped around the cord.
    FixBot'a Sor
  4. Philips DVP642 Power Supply Replacement: adım 4, 1 resimden 1.
    • Remove the ribbon attached to the power supply by pushing the latch and gently pulling up.
    FixBot'a Sor
  5. Philips DVP642 Power Supply Replacement: adım 5, 2 resimden 1. Philips DVP642 Power Supply Replacement: adım 5, 2 resimden 2.
    • Now remove this ribbon wire by grasping the white head firmly and pulling up gently.
    FixBot'a Sor
  6. Philips DVP642 Power Supply Replacement: adım 6, 2 resimden 1. Philips DVP642 Power Supply Replacement: adım 6, 2 resimden 2.
    • Remove these two 7.5m Phillips screws and the matching set at the other end of the supply.
    • Now remove the ribbon that attaches the power supply to the motherboard by grasping the white head and gently pulling up.
    FixBot'a Sor
  7. Philips DVP642 Power Supply Replacement: adım 7, 3 resimden 1. Philips DVP642 Power Supply Replacement: adım 7, 3 resimden 2. Philips DVP642 Power Supply Replacement: adım 7, 3 resimden 3.
    • Remove the last screw.
    • Pinch this plastic prong and slide the power supply up and over it. The power supply should lift free.
    FixBot'a Sor
  8. Philips DVP642 Power Supply Replacement: adım 8, 2 resimden 1. Philips DVP642 Power Supply Replacement: adım 8, 2 resimden 2.
    • Your power supply is now free!
    • If the fuse circled here is blown (the small wire in the glass tube is missing or broken), remove it by pinching it tightly and pulling it straight out.
    • You can find a new fuse here.
    FixBot'a Sor
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Toby Goldsteinholm
372 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-20, Maness Fall 2011 Cal Poly, Team 21-20, Maness Fall 2011 üyesi
CPSU-MANESS-F11S21G20
4 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 109
Her zaman: 14,325
