Ana içeriğe geç
Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement, Philips Emerson CoughAssist CA Series Disassembly: adım 1, 1 resimden 1.
    • First, remove the two 16mm pan head screws (1) directly under the front panel of the ventilator. (Page 3).
    • Next, remove the two 16mm flat head screws (3) from the back panel of the ventilator. (Page 3).
    • Lift off the top cover (2) of the device. (Page 3).
  2. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: adım 4, 2 resimden 1. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: adım 4, 2 resimden 2.
    • Now remove the "Inhale flow" control knob (4) and "Inhale pressure" knob (4), by loosening the setscrew on each before pulling off. If you have a CM model, carefully remove the Manual Control Lever (3) by prying it off with the screwdriver. (Page 3).
  3. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: adım 5, 1 resimden 1.
    • Unscrew the three 12.7mm plastite screws ( 2) holding the panel assembly to the lower housing. A long Phillips screwdriver is very helpful for access to the three screws. (Page 3)
    • The front control panel (5) should now be loose. Carefully slide it forwards to remove. (Page 4).
  4. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement, Valve Actuator Motor: adım 7, 3 resimden 1. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement, Valve Actuator Motor: adım 7, 3 resimden 2. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement, Valve Actuator Motor: adım 7, 3 resimden 3.
    • Position the ventilator so the pressure gauge is facing right to your right.
    • Follow the Preliminary Disassembly Guide to remove the top cover and the front panel.
  5. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: adım 8, 2 resimden 1. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: adım 8, 2 resimden 2.
    • Remove the two 12.7mm plastite screws (10) as shown, and remove the Power Filter (9). (Page 7)
    • Remove all screws holding the Bracket (6) to the Valve Assembly (12). (Page 7)
    • Remove the two 12.7mm plastite screws above and the one screw beneath the Actuator Motor (9). (Page 7)
    • Take out the Actuator Motor (9) while it is still attached to the Bracket (6). (Page 7)
  6. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: adım 9, 1 resimden 1.
    • If you notice other parts are damaged or faulty, replace them. These parts include the torsion spring (1), cable chain (3), larger sprocket (4), or the spacer (2). (Page 7).
    • The small sprocket on the motor is not designed to be removed from the shaft, so make sure you are replacing the large sprocket.
  7. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: adım 10, 2 resimden 1. Philips Emerson CoughAssist CA Series Valve Actuator Motor Replacement: adım 10, 2 resimden 2.
    • Disconnect the two motor terminals from the motor capacitor (7). (Page 7).
    • Remove the 4 6.4mm binding head screws holding the motor to the bracket. (Page 7).
    • Remove the motor. (Page 7)
Sonuç
To reassemble your device, follow these instructions in reverse order. After reassembly, check that the cable chain(3) is tensioned properly. This means that the two sides of the chain can be pinched together almost half way, but not able to touch. If you need more detail or looking for more information on this repair, please refer to the Service Guide attached, page 7.
Zachary Stednitz
292 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S11-G18, Paton Spring 2020 Cal Poly, Team S11-G18, Paton Spring 2020 üyesi
CPSU-PATON-S20S11G18
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 304
