Ana içeriğe geç
Philips HD9252 Latch Button Replacement
Neye ihtiyacın var
    1. Philips HD9252 Latch Button Replacement, Tray: adım 1, 1 resimden 1.
      • Remove the tray from the air fryer by pressing the latch button in, and pulling the handle away.
      FixBot'a Sor
      Yorum Ekle
    2. Philips HD9252 Latch Button Replacement: adım 2, 1 resimden 1.
      • Pull the tray out of the basket.
      FixBot'a Sor
      Yorum Ekle
    1. Philips HD9252 Latch Button Replacement, Latch Button: adım 3, 2 resimden 1. Philips HD9252 Latch Button Replacement, Latch Button: adım 3, 2 resimden 2.
      • Remove the two 14.8 mm screws placed in the top of the latch using a Phillips #00 screwdriver.
      • Remove the two 14.8 mm screws placed on the bottom of the latch using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Philips HD9252 Latch Button Replacement: adım 4, 1 resimden 1.
      • Remove the four 14.8 mm screws placed on front of the latch button using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Philips HD9252 Latch Button Replacement: adım 5, 1 resimden 1.
      • Pry off the back panel of the handle.
      FixBot'a Sor
      Yorum Ekle
    4. Philips HD9252 Latch Button Replacement: adım 6, 2 resimden 1. Philips HD9252 Latch Button Replacement: adım 6, 2 resimden 2.
      • Push the spring down with a nylon spudger so that it is underneath the button.
      • Slide the spring out of the back of the handle.
      FixBot'a Sor
      Yorum Ekle
    5. Philips HD9252 Latch Button Replacement: adım 7, 1 resimden 1.
      • Remove the front of the latch from the handle.
      FixBot'a Sor
      Yorum Ekle
    6. Philips HD9252 Latch Button Replacement: adım 8, 1 resimden 1.
      • Remove the button through the back of the handle.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 28
Son 30 gün: 162
Her zaman: 2,953
