Ana içeriğe geç
Philips HD9252 Touch Screen Motherboard Replacement
Neye ihtiyacın var
  1. Philips HD9252 Touch Screen Motherboard Replacement, Top: adım 1, 1 resimden 1.
    • Insert a nylon spudger underneath the top of the device.
    • Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
  2. Philips HD9252 Touch Screen Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the four 12.4 mm screws in each of the corners using a JIS #1 screwdriver.
  3. Philips HD9252 Touch Screen Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the top by lifting it upwards and setting it down.
  4. Philips HD9252 Touch Screen Motherboard Replacement, Touch Screen Motherboard: adım 4, 2 resimden 1. Philips HD9252 Touch Screen Motherboard Replacement, Touch Screen Motherboard: adım 4, 2 resimden 2.
    • Remove the back panel from the touch screen motherboard by popping the tabs off using the nylon spudger.
  5. Philips HD9252 Touch Screen Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the touch screen motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Zach Person
463 İtibar
4 adet Kılavuz yazıldı
1Rehber Yorum
Does the same method apply to milex airfryer 5.6 litre xxxl ? Coz when I switch it on it does not respond
Morena - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 79
Her zaman: 474
