Giriş
This guide will lead users through the process of replacing a faulty touch screen. This may be required if the touch screen is unresponsive or does not turn on.
Neye ihtiyacın var
Insert a nylon spudger underneath the top of the device.
Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
Remove the back panel from the touch screen motherboard by popping the tabs off using the nylon spudger.
2 farklı kişi bu kılavuzu tamamladı.
