Ana içeriğe geç
Philips HD9252 Transformer Replacement
Neye ihtiyacın var
  1. Philips HD9252 Transformer Replacement, Top: adım 1, 1 resimden 1.
    • Insert a nylon spudger underneath the top of the device.
    • Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
  2. Philips HD9252 Transformer Replacement: adım 2, 1 resimden 1.
    • Remove the four 12.4 mm screws in each of the corners using a JIS #1 screwdriver.
  3. Philips HD9252 Transformer Replacement: adım 3, 1 resimden 1.
    • Remove the top by lifting it upwards and setting it down.
  4. Philips HD9252 Transformer Replacement, Transformer: adım 4, 1 resimden 1.
    • Remove the two 39.5 mm screws attached to the black piece of the transformer using a JIS #1 screwdriver.
  5. Philips HD9252 Transformer Replacement: adım 5, 1 resimden 1.
    • Remove the top piece, using a Phillips #2 screwdriver, to get the whole transformer.
  6. Philips HD9252 Transformer Replacement: adım 6, 2 resimden 1. Philips HD9252 Transformer Replacement: adım 6, 2 resimden 2.
    • Remove the brown and white wire attached to the transformer using a spudger.
    • Disconnect both the brown and white cables.
  7. Philips HD9252 Transformer Replacement: adım 7, 1 resimden 1.
    • Replace the transformer.
Sonuç
Zach Person
463 İtibar
4 adet Kılavuz yazıldı
1Rehber Yorum
This is not the transformer, it is the coil of the shaded-pole motor.
Werner Hinzmann - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 67
Her zaman: 476
