Ana içeriğe geç
Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement
Neye ihtiyacın var
  1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: adım 1, 2 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement, LED Board: adım 1, 2 resimden 2.
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 2, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 2, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 2, 3 resimden 3.
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 3, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 3, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 3, 3 resimden 3.
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 4, 2 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 4, 2 resimden 2.
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 5, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 5, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 5, 3 resimden 3.
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 6, 2 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 6, 2 resimden 2.
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 7, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 7, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 LED Board Replacement: adım 7, 3 resimden 3.
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
August Post
415 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Harley Fall 2017 IUPUI, Team S2-G4, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S2G4
3 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Can you point me in the right direction for finding a replacement board? I’m having trouble finding one. Thanks.
Alex - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 607
