Ana içeriğe geç
Philips Norelco BG2040 BodyGroom 7100 Motor Replacement
Neye ihtiyacın var
  1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, LED Board: adım 1, 2 resimden 1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, LED Board: adım 1, 2 resimden 2.
    • Place thumb behind trimming blade and push up to open.
  2. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 2, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 2, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 2, 3 resimden 3.
    • Remove two screws (M2 x 9.5) on metal plate with JIS 0 screwdriver bit.
    • Use spudger to pry off metal plate.
    • Slide up plastic housing to remove the trimmer.
  3. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 3, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 3, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 3, 3 resimden 3.
    • Slide chrome outer plastic towards removed trimmer.
    • Flip to the other side and repeat, sliding the chrome plastic towards removed trimmer.
  4. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 4, 2 resimden 1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 4, 2 resimden 2.
    • Remove two top screws (M2 x 6.9) with the JIS 00 screwdriver bit.
    • Remove two bottom screws (M2 x 6.9) with the same bit.
  5. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 5, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 5, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 5, 3 resimden 3.
    • Use spudger to pry off top of the battery cover. WARNING: fairly difficult, be aware significant amount of force required.
    • Use spudger to remove bottom of the battery cover, and remove it.
  6. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 6, 2 resimden 1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 6, 2 resimden 2.
    • Use a nylon spudger to pry out battery pack and the attached LED board.
  7. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 7, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 7, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 7, 3 resimden 3.
    • Unwrap electrical tape around the battery pack and LED board.
    • Desolder the LED board from the battery pack.
    • Solder the new LED board back to the connection to battery pack.
  8. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: adım 8, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: adım 8, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement, Motor: adım 8, 3 resimden 3.
    • *Please note that you do not need to remove the LED board from the battery pack for this guide. Begin the following steps after removal of the entire battery pack.*
    • Using the spudger, unclip the plastic housing around white casing.
    • Remove one half of the black housing first, and then proceed to the next half.
  9. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 9, 1 resimden 1.
    • Once housing is removed, pull off shaver head. *Once black housing is removed this part may fall off*
  10. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 10, 3 resimden 1. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 10, 3 resimden 2. Philips Norelco BG2040 BodyGroom 7100 Motor Replacement: adım 10, 3 resimden 3.
    • Use spudger to pry motor out of the white housing.
    • Pull waterproofing case off of the motor.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
August Post
415 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G4, Harley Fall 2017 IUPUI, Team S2-G4, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S2G4
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
Great guide. Thanks
Steve Riggle - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 2,552
