Ana içeriğe geç
Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement, Front and Back Panels: adım 1, 1 resimden 1.
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 2, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 2, 2 resimden 2.
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 3, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 3, 2 resimden 2.
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 4, 3 resimden 1. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 4, 3 resimden 2. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 4, 3 resimden 3.
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 5, 3 resimden 1. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 5, 3 resimden 2. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 5, 3 resimden 3.
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 6, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 6, 2 resimden 2.
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 7, 1 resimden 1.
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 8, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Front and Back Panels Replacement: adım 8, 2 resimden 2.
Sonuç
Darren Chu
1.617 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-2, Blackwell Fall 2015 USF Tampa, Team 15-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G2
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 90
