Ana içeriğe geç
Philips Norelco BeardTrimmer 3100 Handle Replacement
Neye ihtiyacın var
  1. Philips Norelco BeardTrimmer 3100 Handle Replacement, Front and Back Panels: adım 1, 1 resimden 1.
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 2, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 2, 2 resimden 2.
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 3, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 3, 2 resimden 2.
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 4, 3 resimden 1. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 4, 3 resimden 2. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 4, 3 resimden 3.
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 5, 3 resimden 1. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 5, 3 resimden 2. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 5, 3 resimden 3.
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 6, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 6, 2 resimden 2.
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 7, 1 resimden 1.
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 8, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Handle Replacement: adım 8, 2 resimden 2.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
filmon gebregergis
143 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 15-2, Blackwell Fall 2015 USF Tampa, Team 15-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G2
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 5,740
