Ana içeriğe geç
Philips Norelco BeardTrimmer 3100 Power Switch Replacement
Neye ihtiyacın var
  1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Front and Back Panels: adım 1, 1 resimden 1.
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 2, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 2, 2 resimden 2.
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 3, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 3, 2 resimden 2.
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 4, 3 resimden 1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 4, 3 resimden 2. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 4, 3 resimden 3.
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 5, 3 resimden 1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 5, 3 resimden 2. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 5, 3 resimden 3.
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 6, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 6, 2 resimden 2.
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 7, 1 resimden 1.
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 8, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 8, 2 resimden 2.
  9. Philips Norelco BeardTrimmer 3100 Power Switch Replacement, Power Switch: adım 9, 1 resimden 1.
    • Remove the front panel completely from the rest of the beard trimmer.
  10. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 10, 1 resimden 1.
    • Rotate the front panel so that the power switch is facing away from you.
  11. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 11, 3 resimden 1. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 11, 3 resimden 2. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 11, 3 resimden 3.
    • Push the white plastic frame upward to remove it from the notch.
    • Pull the white plastic frame off the front panel of the beard trimmer.
  12. Philips Norelco BeardTrimmer 3100 Power Switch Replacement: adım 12, 1 resimden 1.
    • Remove the power switch from the front panel once the white plastic frame is removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tamara Titus
157 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 15-2, Blackwell Fall 2015 USF Tampa, Team 15-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G2
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 6,096
