Ana içeriğe geç
Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement
Neye ihtiyacın var
  1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement, Front and Back Panels: adım 1, 1 resimden 1.
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 2, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 2, 2 resimden 2.
    • Place your thumb underneath the blade and push upward to remove it.
  3. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 3, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 3, 2 resimden 2.
    • Hold trimmer towards you as shown in the diagram.
    • Insert your prying tool/metal spudger into the marked area.
  4. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 4, 3 resimden 1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 4, 3 resimden 2. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 4, 3 resimden 3.
    • Apply gentle pressure and begin prying open the back panel.
    • Separate the panel one notch at a time. Listen carefully as you're prying the panel apart and notice each individual notch release.
  5. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 5, 3 resimden 1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 5, 3 resimden 2. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 5, 3 resimden 3.
    • Pull the trimmer apart using your hands once the panel is at least halfway apart.
    • Pull the wires attached to the battery off of the power connectors before completely removing the back panel.
  6. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 6, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 6, 2 resimden 2.
    • Hold the trimmer towards you.
    • Place the metal spudger tool in the marked area.
  7. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 7, 1 resimden 1.
    • Apply gentle pressure and begin prying the front panel.
    • Separate the front panel one notch at a time.
  8. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 8, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 8, 2 resimden 2.
  9. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement, Zoom Lock Precision Notch: adım 9, 1 resimden 1.
    • Locate the zoom lock precision notch in the back panel of the Beardtrimmer
  10. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 10, 1 resimden 1.
    • Set the zoom lock wheel to the lowest setting
  11. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 11, 2 resimden 1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 11, 2 resimden 2.
    • Rotate the trimmer so that the motor is facing you.
    • Now gently push down the zoom lock wheel until the white button is not showing.
  12. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 12, 3 resimden 1. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 12, 3 resimden 2. Philips Norelco BeardTrimmer 3100 Zoom Lock Precision Notch Replacement: adım 12, 3 resimden 3.
    • Rotate the beardtrimmer again so that the battery is facing you.
    • With the help of the metal spudger, apply gentle pressure on top of the wheel to remove the zoom lock precision notch .
Sonuç
ilan
173 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 15-2, Blackwell Fall 2015 USF Tampa, Team 15-2, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G2
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
How to fix charging wire to the plate?
Kartik Gusain - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 4,602
