Ana içeriğe geç
Philips Norelco MultiGroom 3100 Casing Replacement
Neye ihtiyacın var
  1. Philips Norelco MultiGroom 3100 Casing Replacement, Power Button: adım 1, 1 resimden 1.
    • Remove the comb from the top of the trimmer.
  2. Philips Norelco MultiGroom 3100 Casing Replacement: adım 2, 2 resimden 1. Philips Norelco MultiGroom 3100 Casing Replacement: adım 2, 2 resimden 2.
    • Grip the attachment and twist it counterclockwise until you hear a click.
    • Pull the attachment up to remove it from the trimmer.
  3. Philips Norelco MultiGroom 3100 Casing Replacement: adım 3, 2 resimden 1. Philips Norelco MultiGroom 3100 Casing Replacement: adım 3, 2 resimden 2.
    • Hold the trimmer upright so it is facing you.
    • Insert the plastic opening tool in the gap at the top of the power button.
  4. Philips Norelco MultiGroom 3100 Casing Replacement: adım 4, 1 resimden 1.
    • Apply pressure to pry off the power button.
  5. Philips Norelco MultiGroom 3100 Casing Replacement, Casing: adım 5, 2 resimden 1. Philips Norelco MultiGroom 3100 Casing Replacement, Casing: adım 5, 2 resimden 2.
    • Insert the spudger into the bottom of the gray bezel and begin to gently pry it off.
    • Separate the bezel one clip at a time so that the clips do not break.
  6. Philips Norelco MultiGroom 3100 Casing Replacement: adım 6, 2 resimden 1. Philips Norelco MultiGroom 3100 Casing Replacement: adım 6, 2 resimden 2.
    • Insert the spudger in the indicated hole and apply a tilting force to loosen the outer casing.
    • Pull upward on the top of the inner housing to remove it from the outer casing.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
ahaharevolution
771 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Leahy Fall 2015 USF Tampa, Team 1-1, Leahy Fall 2015 üyesi
USFT-LEAHY-F15S1G1
2 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 34
Her zaman: 5,250
