Ana içeriğe geç
Philips Norelco OneBlade Exterior Casing Replacement
Neye ihtiyacın var
  1. Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: adım 1, 3 resimden 1. Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: adım 1, 3 resimden 2. Philips Norelco OneBlade Exterior Casing Replacement, Exterior Casing: adım 1, 3 resimden 3.
    • Ensure razor is off, and razor blade has been removed.
  2. Philips Norelco OneBlade Exterior Casing Replacement: adım 2, 2 resimden 1. Philips Norelco OneBlade Exterior Casing Replacement: adım 2, 2 resimden 2.
    • Locate crease in bottom third of razor.
    • Hold razor in both hands, and place thumbs near crease.
    • Slightly bend the razor near crease.
    • Pull top razor apart.
    • Caution, device may turn on upon removal. Turn off razor before continuing.
  3. Philips Norelco OneBlade Exterior Casing Replacement: adım 3, 1 resimden 1.
    • Power button should face forward in same direction as circuit board. The crease on each casing component should line up.
Sonuç
Please dispose of exterior casing properly. For recycling information, please contact your local waste management facilities or visit www.recycle.philips.com
Joshua Etchberger
472 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Harley Fall 2017 IUPUI, Team S3-G3, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S3G3
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 26
Son 30 gün: 71
Her zaman: 3,603
