Ana içeriğe geç
Philips Norelco Shaver 2100 Casing Replacement
Neye ihtiyacın var
  1. Philips Norelco Shaver 2100 Casing Replacement, Casing: adım 1, 1 resimden 1.
    • Remove the single screw on the back casing using a T8 Torx screwdriver.
  2. Philips Norelco Shaver 2100 Casing Replacement: adım 2, 2 resimden 1. Philips Norelco Shaver 2100 Casing Replacement: adım 2, 2 resimden 2.
    • Turn the shaver so that it is facing you.
    • Press the button on the shaver head to open it.
  3. Philips Norelco Shaver 2100 Casing Replacement: adım 3, 1 resimden 1.
    • Remove the two 10.1 mm screws inside the shaver head using a T8 Torx screwdriver.
  4. Philips Norelco Shaver 2100 Casing Replacement: adım 4, 2 resimden 1. Philips Norelco Shaver 2100 Casing Replacement: adım 4, 2 resimden 2.
    • Lift the shaver head off of the casing.
  5. Philips Norelco Shaver 2100 Casing Replacement: adım 5, 3 resimden 1. Philips Norelco Shaver 2100 Casing Replacement: adım 5, 3 resimden 2. Philips Norelco Shaver 2100 Casing Replacement: adım 5, 3 resimden 3.
    • Gently pull the black and blue casing apart using a metal spudger.
  6. Philips Norelco Shaver 2100 Casing Replacement: adım 6, 3 resimden 1. Philips Norelco Shaver 2100 Casing Replacement: adım 6, 3 resimden 2. Philips Norelco Shaver 2100 Casing Replacement: adım 6, 3 resimden 3.
    • Pry the remaining casing open using a metal spudger.
    • Be careful using a metal spudger, as it may result in damaging the case.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jose Moya
194 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Thompson Fall 2017 USF Tampa, Team S1-G4, Thompson Fall 2017 üyesi
USFT-THOMPSON-F17S1G4
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,161
