Ana içeriğe geç
Philips Norelco Shaver Head Blade Replacement
Neye ihtiyacın var
  1. Philips Norelco Shaver Head Blade Replacement, Philips Norelco Shaver Head Blade: adım 1, 2 resimden 1. Philips Norelco Shaver Head Blade Replacement, Philips Norelco Shaver Head Blade: adım 1, 2 resimden 2.
    • Begin by pressing the small button beneath the head to allow it to open.
  2. Philips Norelco Shaver Head Blade Replacement: adım 2, 2 resimden 1. Philips Norelco Shaver Head Blade Replacement: adım 2, 2 resimden 2.
    • Grasp the sides of the head and pull straight up to detach it from the body.
  3. Philips Norelco Shaver Head Blade Replacement: adım 3, 2 resimden 1. Philips Norelco Shaver Head Blade Replacement: adım 3, 2 resimden 2.
    • To unlock, rotate the center locking mechanism counter-clockwise.
  4. Philips Norelco Shaver Head Blade Replacement: adım 4, 1 resimden 1.
    • Lift the locking mechanism straight up, freeing the blades.
  5. Philips Norelco Shaver Head Blade Replacement: adım 5, 3 resimden 1. Philips Norelco Shaver Head Blade Replacement: adım 5, 3 resimden 2. Philips Norelco Shaver Head Blade Replacement: adım 5, 3 resimden 3.
    • Carefully push the blades out from behind.
    • Although the blades are covered, they can fall apart, exposing sharp edges. Always use care when handling.
  6. Philips Norelco Shaver Head Blade Replacement: adım 6, 3 resimden 1. Philips Norelco Shaver Head Blade Replacement: adım 6, 3 resimden 2. Philips Norelco Shaver Head Blade Replacement: adım 6, 3 resimden 3.
    • Insert the new blades, making sure to face the side with the two tabs towards the center of the head.
  7. Philips Norelco Shaver Head Blade Replacement: adım 7, 3 resimden 1. Philips Norelco Shaver Head Blade Replacement: adım 7, 3 resimden 2. Philips Norelco Shaver Head Blade Replacement: adım 7, 3 resimden 3.
    • Line up the locking mechanism with the new blades, then rotate the center clockwise to lock down.
  8. Philips Norelco Shaver Head Blade Replacement: adım 8, 3 resimden 1. Philips Norelco Shaver Head Blade Replacement: adım 8, 3 resimden 2. Philips Norelco Shaver Head Blade Replacement: adım 8, 3 resimden 3.
    • Push the head back onto the body, then close it up. Your shaver is good to go!
Bitiş Çizgisi
16 farklı kişi bu kılavuzu tamamladı.
Austin Fisher
518 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-1, Green Fall 2015 Cal Poly, Team 10-1, Green Fall 2015 üyesi
CPSU-GREEN-F15S10G1
4 Üyeler
7 adet Kılavuz yazıldı
9 Yorum
This is a good guide thank you.
Replacing these shaver batteries would be a good guide: does anyone know how to do this?
Richard - Yanıt
Very well done - better than a video because you don’t need to continually stop, restart and rewind to catch specific details.
Clif T - Yanıt
The only problem I had was to insert the hinge into the body. Didn't want to push too hard as I was worried I could snap off some plastic parts. Once I had pushed the OLD unit on and off a couple of times the new one went in quite easily ( although the old unit was much more free than the new unit). Many thanks for your instructions - most useful!
Mike L. 14 March 2022
mike lowe - Yanıt
How do you change the trimmer blade on back of it ? Or can you ?
Melanie Gettys - Yanıt
Clear and simple tutorial. Excellent!
Greg Fullmer - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 33
Son 30 gün: 105
Her zaman: 47,719
