Ana içeriğe geç
Philips Respironics System One REMstar Blower Unit Replacement
Neye ihtiyacın var
  1. Philips Respironics System One REMstar Blower Unit Replacement, Blower Unit: adım 1, 1 resimden 1.
    • Turn the device upside down so that the rubber feet are facing you.
    • Use the TR15 screw head to remove the two 46.5mm length crews located on the back.
    • Gently remove the casing so that the wires are not damaged.
  2. Philips Respironics System One REMstar Blower Unit Replacement: adım 2, 1 resimden 1.
    • Using a Torx TR10 screwdriver, remove the seven 13.5 mm screws that are securing the inner casing.
    • Remove the inner casing.
  3. Philips Respironics System One REMstar Blower Unit Replacement: adım 3, 1 resimden 1.
    • Remove the motor from the bottom half of the inner casing and set it to the side.
  4. Philips Respironics System One REMstar Blower Unit Replacement: adım 4, 2 resimden 1. Philips Respironics System One REMstar Blower Unit Replacement: adım 4, 2 resimden 2.
    • Remove the circular piece by popping it off to separate the circuit board from the top cover.
    • No tools should be necessary to complete this action.
  5. Philips Respironics System One REMstar Blower Unit Replacement: adım 5, 2 resimden 1. Philips Respironics System One REMstar Blower Unit Replacement: adım 5, 2 resimden 2.
    • Disconnect the green and red wire connectors from their white connectors to disconnect the blower motor.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
These steps may be out of sequential order. Step 4 should probably be Step 1 and perhaps some are even missing.
Charles Marshall - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 1,228
