Ana içeriğe geç
Philips Respironics V60 Fan Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Philips Respironics V60 Fan Replacement, shut down the ventilator: adım 1, 2 resimden 1. Philips Respironics V60 Fan Replacement, shut down the ventilator: adım 1, 2 resimden 2.
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
    FixBot'a Sor
    Yorum Ekle
    • Disconnect the ventilator from the AC power.
    FixBot'a Sor
    Yorum Ekle
    • Unplug the ventilator
    FixBot'a Sor
    Yorum Ekle
  2. Philips Respironics V60 Fan Replacement: adım 4, 1 resimden 1.
    • Disconnect the internal battery from the power harness connector.
    FixBot'a Sor
    Yorum Ekle
  3. Philips Respironics V60 Fan Replacement, Top Cover: adım 5, 1 resimden 1.
    • Turn the captive D-ring fastener on the bottom of the panel counter-clockwise one-quarter turn and release.
    • Then remove the right side panel.
    FixBot'a Sor
    Yorum Ekle
  4. Philips Respironics V60 Fan Replacement: adım 6, 1 resimden 1.
    • Remove the 4 screws using a screwdriver.
    • Remove the top cover.
    FixBot'a Sor
    Yorum Ekle
  5. Philips Respironics V60 Fan Replacement, Fan: adım 7, 1 resimden 1.
    • Remove the fan mount push pins that attach the fan to the back panel.
    • Pliers may be required.
    FixBot'a Sor
    Yorum Ekle
  6. Philips Respironics V60 Fan Replacement: adım 8, 1 resimden 1.
    • Disconnect fan cable from motor controller.
    FixBot'a Sor
    Yorum Ekle
  7. Philips Respironics V60 Fan Replacement: adım 9, 1 resimden 1.
    • Remove fan,
    • from back panel.
    FixBot'a Sor
    Yorum Ekle
  8. Philips Respironics V60 Fan Replacement: adım 10, 1 resimden 1.
    • Remove fan filter assembly (the fan filter and housing), from outside the back panel.
    • When installing, orient the fan with the fan cable at the top inside of the fan, and orient the fan filter and housing as shown.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Rie Kuraoka
913 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G10, Paton Spring 2020 Cal Poly, Team S7-G10, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G10
2 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 1,032
