Ana içeriğe geç
Philips Respironics V60 Top Cover Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
Neye ihtiyacın var
  1. Philips Respironics V60 Top Cover Replacement, shut down the ventilator: adım 1, 2 resimden 1. Philips Respironics V60 Top Cover Replacement, shut down the ventilator: adım 1, 2 resimden 2.
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
    • Disconnect the ventilator from the AC power.
    • Unplug the ventilator
  2. Philips Respironics V60 Top Cover Replacement: adım 4, 1 resimden 1.
    • Disconnect the internal battery from the power harness connector.
  3. Philips Respironics V60 Top Cover Replacement, Top Cover: adım 5, 1 resimden 1.
    • Turn the captive D-ring fastener on the bottom of the panel counter-clockwise one-quarter turn and release.
    • Then remove the right side panel.
  4. Philips Respironics V60 Top Cover Replacement: adım 6, 1 resimden 1.
    • Remove the 4 screws using a screwdriver.
    • Remove the top cover.
Sonuç
Rie Kuraoka
886 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G10, Paton Spring 2020 Cal Poly, Team S7-G10, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G10
2 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 268
