Ana içeriğe geç
Philips Respironics V60 Touchscreen Replacement
Tıbbi Ekipman
iFixit de, bu onarım kılavuzu da tıbbi cihaz üreticisi tarafından onaylanmış değildir ya da herhangi birinin üreticiyle alâkası yoktur.
  1. Philips Respironics V60 Touchscreen Replacement, Touchscreen: adım 1, 1 resimden 1.
    • From the Diagnostics Menu, select Touch Screen Calibration. The Calibrate Touch Screen screen is displayed.
    • Follow the steps shown. Press on the middle of each target with a blunt, narrow object.
    • NOTE: If the Touch Screen Calibration button does not respond, press the Accept button on the navigation ring to begin
    • If the calibration is not successful, have the ventilator serviced.
  2. Philips Respironics V60 Touchscreen Replacement: adım 2, 1 resimden 1.
    • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
    • Select Ventilator Shutdown, which will shut down the ventilator.
    • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
  3. Philips Respironics V60 Touchscreen Replacement: adım 3, 1 resimden 1.
    • Remove the screws from the end cap and remove the end cap.
    • Remove the screws from the rear bezel.
    • Separate the front and rear bezel.
  4. Philips Respironics V60 Touchscreen Replacement: adım 4, 1 resimden 1.
    • Disconnect these cables from the UI PCBA: • Switch PCBA cable • Nav-ring cable • Power switch overlay cable • Touch screen cable
    • Remove the switch PCBA.
    • Remove the screw that attaches the cable clamp to the LCD tray.
    • Remove the screws and washers that attach the LCD tray to the front bezel, then remove the LCD tray.
    • Remove the touch screen from the front bezel.
Sonuç
Weihan Du
241 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S7-G10, Paton Spring 2020 Cal Poly, Team S7-G10, Paton Spring 2020 üyesi
CPSU-PATON-S20S7G10
2 Üyeler
9 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 64
Her zaman: 2,691
