Ana içeriğe geç
Philips SBA1060 Capacitor Replacement
Neye ihtiyacın var
  1. Philips SBA1060 Capacitor Replacement, Battery Casing: adım 1, 1 resimden 1.
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
    FixBot'a Sor
    Yorum Ekle
  2. Philips SBA1060 Capacitor Replacement: adım 2, 3 resimden 1. Philips SBA1060 Capacitor Replacement: adım 2, 3 resimden 2. Philips SBA1060 Capacitor Replacement: adım 2, 3 resimden 3.
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
    FixBot'a Sor
    Yorum Ekle
  3. Philips SBA1060 Capacitor Replacement: adım 3, 2 resimden 1. Philips SBA1060 Capacitor Replacement: adım 3, 2 resimden 2.
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
    FixBot'a Sor
    Yorum Ekle
  4. Philips SBA1060 Capacitor Replacement, Capacitor: adım 4, 1 resimden 1.
    • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
    • Slowly pull the circuit board out of the device
    • NOTE: Be careful not to damage any of the wires protruding from the back of the circuit board.
    FixBot'a Sor
    Yorum Ekle
  5. Philips SBA1060 Capacitor Replacement: adım 5, 2 resimden 1. Philips SBA1060 Capacitor Replacement: adım 5, 2 resimden 2.
    • Flip the device and remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
    • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
    • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
    • Remove the light plug from the circuit board.
    • NOTE: This plug is twice as wide as the speaker and battery plugs.
    FixBot'a Sor
    Yorum Ekle
  6. Philips SBA1060 Capacitor Replacement: adım 6, 2 resimden 1. Philips SBA1060 Capacitor Replacement: adım 6, 2 resimden 2.
    • Locate the capacitor and carefully slide it out of the circuit board.
    • NOTE: The capacitor will be a cylindrical object protruding vertically near the center of the circuit board.
    • Slide the prongs of the replacement capacitor into the two holes of the circuit board where the original capacitor was removed from.
    • Reassemble the speaker.
    FixBot'a Sor
    Yorum Ekle
Sonuç
April Driscoll
321 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G4
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 1,043
