Ana içeriğe geç
Philips SBA1060 Circuit Board Replacement
Neye ihtiyacın var
  1. Philips SBA1060 Circuit Board Replacement, Battery Casing: adım 1, 1 resimden 1.
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Philips SBA1060 Circuit Board Replacement: adım 2, 3 resimden 1. Philips SBA1060 Circuit Board Replacement: adım 2, 3 resimden 2. Philips SBA1060 Circuit Board Replacement: adım 2, 3 resimden 3.
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Philips SBA1060 Circuit Board Replacement: adım 3, 2 resimden 1. Philips SBA1060 Circuit Board Replacement: adım 3, 2 resimden 2.
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
  4. Philips SBA1060 Circuit Board Replacement, Circuit Board: adım 4, 1 resimden 1.
    • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
    • Remove the damaged circuit board from the device.
  5. Philips SBA1060 Circuit Board Replacement: adım 5, 2 resimden 1. Philips SBA1060 Circuit Board Replacement: adım 5, 2 resimden 2.
    • Remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
    • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
    • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
    • Remove the light plug from the circuit board.
    • NOTE: This plug is twice as wide as the speaker and battery plugs.
    • Reassemble the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
April Driscoll
321 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G4
3 Üyeler
4 adet Kılavuz yazıldı
2 Yorum
Is that one of those cheap pam amps that run from 5v?
fabio souza jr - Yanıt
Nice picture,it helps a lot in trouble shooting !
sergio - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 13
Her zaman: 1,312
