Ana içeriğe geç
Philips SBA1060 Speaker Replacement
Neye ihtiyacın var
  1. Philips SBA1060 Speaker Replacement, Battery Casing: adım 1, 1 resimden 1.
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Philips SBA1060 Speaker Replacement: adım 2, 3 resimden 1. Philips SBA1060 Speaker Replacement: adım 2, 3 resimden 2. Philips SBA1060 Speaker Replacement: adım 2, 3 resimden 3.
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Philips SBA1060 Speaker Replacement: adım 3, 2 resimden 1. Philips SBA1060 Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
  4. Philips SBA1060 Speaker Replacement, Speaker: adım 4, 2 resimden 1. Philips SBA1060 Speaker Replacement, Speaker: adım 4, 2 resimden 2.
    • Remove the circuit board by unscrewing the two interior screws located on the circuit board.
    • Pull out the battery plugs from the circuit board by pulling out the plugs to fully remove the back panel from the rest of the speaker.
  5. Philips SBA1060 Speaker Replacement: adım 5, 2 resimden 1. Philips SBA1060 Speaker Replacement: adım 5, 2 resimden 2.
    • Locate the speaker needing replacing.
    • Remove the one screw holding the speaker in place with a PH0 size philips head screw driver.
  6. Philips SBA1060 Speaker Replacement: adım 6, 3 resimden 1. Philips SBA1060 Speaker Replacement: adım 6, 3 resimden 2. Philips SBA1060 Speaker Replacement: adım 6, 3 resimden 3.
    • Score the glue that is holding the speaker in place with the spudger, and use your hands to pry off the speaker.
  7. Philips SBA1060 Speaker Replacement: adım 7, 2 resimden 1. Philips SBA1060 Speaker Replacement: adım 7, 2 resimden 2.
    • Using a non-conductive glue, carefully seal the speaker to the casing.
    • Follow the glue instructions as set by the manufacturers. Let the glue set the appropriate amount of time.
    • Reassemble the device
Sonuç
Bir başkası bu kılavuzu tamamladı.
April Driscoll
321 İtibar
3 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-4, Benson Fall 2013 Clemson, Team 14-4, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G4
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 19
Her zaman: 1,719
