Ana içeriğe geç
Philips Satinelle Motor Replacement
Neye ihtiyacın var
  1. Philips Satinelle Motor Replacement, Plastic Cover: adım 1, 3 resimden 1. Philips Satinelle Motor Replacement, Plastic Cover: adım 1, 3 resimden 2. Philips Satinelle Motor Replacement, Plastic Cover: adım 1, 3 resimden 3.
    • Remove the head by pushing it to the right.
    FixBot'a Sor
    Yorum Ekle
  2. Philips Satinelle Motor Replacement: adım 2, 2 resimden 1. Philips Satinelle Motor Replacement: adım 2, 2 resimden 2.
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
    FixBot'a Sor
    Yorum Ekle
  3. Philips Satinelle Motor Replacement: adım 3, 1 resimden 1.
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
    FixBot'a Sor
    Yorum Ekle
  4. Philips Satinelle Motor Replacement, Motor: adım 4, 2 resimden 1. Philips Satinelle Motor Replacement, Motor: adım 4, 2 resimden 2.
    • Remove the components.
    FixBot'a Sor
    Yorum Ekle
  5. Philips Satinelle Motor Replacement: adım 5, 3 resimden 1. Philips Satinelle Motor Replacement: adım 5, 3 resimden 2. Philips Satinelle Motor Replacement: adım 5, 3 resimden 3.
    • Hold the motor with the gears face away from you.
    • Gently push the motor out with your thumbs.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Madeline Casalino
325 İtibar
3 adet Kılavuz yazıldı
Ekip
Marist, Team S1-G1, Chaterdon Fall 2018 Marist, Team S1-G1, Chaterdon Fall 2018 üyesi
MARS-CHATERDON-F18S1G1
3 Üyeler
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
i dont know what i am doing wrong but it is not openning
Aj Queen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 59
Her zaman: 2,914
