Ana içeriğe geç
Philips Satinelle Plastic Cover Replacement
Neye ihtiyacın var
  1. Philips Satinelle Plastic Cover Replacement, Plastic Cover: adım 1, 3 resimden 1. Philips Satinelle Plastic Cover Replacement, Plastic Cover: adım 1, 3 resimden 2. Philips Satinelle Plastic Cover Replacement, Plastic Cover: adım 1, 3 resimden 3.
    • Remove the head by pushing it to the right.
  2. Philips Satinelle Plastic Cover Replacement: adım 2, 2 resimden 1. Philips Satinelle Plastic Cover Replacement: adım 2, 2 resimden 2.
    • Use a metal spudger to pry open the casing.
    • Caution: The epilator's internal components could be damaged if you shove the spudger in too far.
  3. Philips Satinelle Plastic Cover Replacement: adım 3, 1 resimden 1.
    • Pull the plastic casing apart with your hands.
    • The plastic tab connecting the cover is likely going to break when you pull the device apart. This will not affect the operation of the epilator.
Sonuç
To reassemble your device, move the components from the broken shell into the new shell and follow these instructions in reverse order.
Madeline Casalino
313 İtibar
3 adet Kılavuz yazıldı
Ekip
Marist, Team S1-G1, Chaterdon Fall 2018 Marist, Team S1-G1, Chaterdon Fall 2018 üyesi
MARS-CHATERDON-F18S1G1
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 581
