Giriş
If the pump does not work, a replacement may help. This is shown here.
Neye ihtiyacın var
Remove all attachments such as cup rack, pod holder and water tank.
The side panel must first be detached at the bottom edge. Turn the machine so that the bottom is facing towards you.
There are two indentations on the base plate with catches inside each one. Press in the catches with a screwdriver and detach the side panel at the bottom edge.
Chances are the plate will get stuck. It is recommended that you use a plastic pry tool to avoid scratching.
Cut the two cable ties.
Disconnect the flat connectors on the white and brown cables.
Slide off the black and the white hose.
Pull the pump first out of the left, then out of the right rubber holder.
Remove the pump.
Other source for the replacement, pay attention to the price: ULKA-HF Pump
Work through the steps in reverse order to reassemble your device.
Note: Do not forget to replace the cut cable ties with new ones.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
