Giriş
This guide will show you how to replace the circuit board for the Philips Sonicare 2 Series toothbrush. He is a link for a guide how to soldering which will be needed for this guide. How To Solder and Desolder Connections
Neye ihtiyacın var
Pull upwards to remove the brush head from the top of the device.
Pry away the battery using an opening tool from the battery housing. This will break the circuit and avoid electric shock.
Bir başkası bu kılavuzu tamamladı.
