Ana içeriğe geç
Philips Sonicare FlexCare Shaft Replacement
Neye ihtiyacın var
  1. Philips Sonicare FlexCare Shaft Replacement, Shaft: adım 1, 1 resimden 1.
    • Pull the brush head away from the handle to remove it.
  2. Philips Sonicare FlexCare Shaft Replacement: adım 2, 1 resimden 1.
    • Have a look to an alternative opening procedure.
    • Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
  3. Philips Sonicare FlexCare Shaft Replacement: adım 3, 2 resimden 1. Philips Sonicare FlexCare Shaft Replacement: adım 3, 2 resimden 2.
    • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the electronics located in the interior are exposed.
  4. Philips Sonicare FlexCare Shaft Replacement: adım 4, 1 resimden 1.
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Philips Sonicare FlexCare Shaft Replacement: adım 5, 1 resimden 1.
    • Using a #00 phillips head screwdriver, loosen the screw completely.
  6. Philips Sonicare FlexCare Shaft Replacement: adım 6, 1 resimden 1.
    • Rotate the interior of the toothbrush until the screw is facing downward. Slightly shake the interior so that the screw with its accompanying metal part fall out.
    • Slightly shake the interior so that the screw falls out.
    • A small ring may fall out when the screw is removed. Be careful not to lose the ring.
  7. Philips Sonicare FlexCare Shaft Replacement: adım 7, 1 resimden 1.
    • Use a metal probe to press against the hole located at the edge of the interior. While applying this pressure, pull on the shaft outward. Repeat this step on the opposite side.
    • A small nut may fall out when the shaft is removed. Be careful not to lose the nut.
  8. Philips Sonicare FlexCare Shaft Replacement: adım 8, 1 resimden 1.
    • Once the shaft is released, separate it from the body of the interior.
    • Insert the replacement shaft by aligning the the components and applying a force to insert the legs (one of the legs is identified by the red arrow) of the shaft into the interior.
Sonuç
47 farklı kişi bu kılavuzu tamamladı.
Tasha Panattoni
769 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-6, Maness Spring 2015 Cal Poly, Team 4-6, Maness Spring 2015 üyesi
CPSU-MANESS-S15S4G6
4 Üyeler
23 adet Kılavuz yazıldı
37 Yorum
Where do you get a replacement shaft? I can't find any online
noahmckinnon - Yanıt
You don't need to pry the bottom plate off and risk damaging the seal. Simply apply firm pressure on the shaft against a table while simultaneously wiggling the bottom plate back and forth with a large flathead screwdriver inserted into the charging hole on the bottom. It will pop off smoothly leaving the seal untouched and not scratching the housing or charging plug.
jelneutron3 - Yanıt
I can not find the shaft anywhere who sells them
bennie - Yanıt
Like the previous comments I also am looking for the replacement shaft. If anyone has found a source please leave a comment with regards to where they can be found.
Thanks for the help
Lino Valadas - Yanıt
Like everyone above, I can't locate the "replacement shaft". Anyone have any ideas who might have one? A $179 toothbrush should last more than the one year warranty! Is the Braun Oral-B any better?
pgootos - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 122
Son 7 gün: 962
Son 30 gün: 3,924
Her zaman: 235,592
