Ana içeriğe geç
Philips Sonicare FlexCare Spring Replacement
Neye ihtiyacın var
  1. Philips Sonicare FlexCare Spring Replacement, Spring: adım 1, 1 resimden 1.
    • Pull the brush head away from the handle to remove it.
  2. Philips Sonicare FlexCare Spring Replacement: adım 2, 2 resimden 1. Philips Sonicare FlexCare Spring Replacement: adım 2, 2 resimden 2.
    • Push the flat edge of a nylon or metal spudger between the seal and the toothbrush body and pry it up. Do this on each side until the seal is partially sticking out on all sides.
  3. Philips Sonicare FlexCare Spring Replacement: adım 3, 1 resimden 1.
    • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the interior electronics are exposed.
  4. Philips Sonicare FlexCare Spring Replacement: adım 4, 1 resimden 1.
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Philips Sonicare FlexCare Spring Replacement: adım 5, 1 resimden 1.
    • Pull off the black rubber ring with a metal or nylon spudger until it clears the metal piece that holds it in place. Pull the ring out.
  6. Philips Sonicare FlexCare Spring Replacement: adım 6, 1 resimden 1.
    • Remove the spring from the rubber ring and replace it with the new spring.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Joanna Moraza
1.765 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-6, Maness Spring 2015 Cal Poly, Team 4-6, Maness Spring 2015 üyesi
CPSU-MANESS-S15S4G6
4 Üyeler
23 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 67
Her zaman: 5,012
