Ana içeriğe geç
Philips Sonicare ProtectiveClean 6500 Battery Replacement
Neye ihtiyacın var
  1. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: adım 1, 3 resimden 1. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: adım 1, 3 resimden 2. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Internal Assembly: adım 1, 3 resimden 3.
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Battery Replacement: adım 2, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Battery Replacement: adım 2, 2 resimden 2.
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Battery Replacement: adım 3, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Battery Replacement: adım 3, 2 resimden 2.
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Use an opening tool to gently pry up the battery.
    • Remove the battery.
Sonuç
Liam Casto
354 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Harley Spring 2024 IUPUI, Team 1-4, Harley Spring 2024 üyesi
IUPUI-HARLEY-S24S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 26
Her zaman: 85
