Ana içeriğe geç
Philips Sonicare ProtectiveClean 6500 Motor Replacement
Neye ihtiyacın var
  1. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: adım 1, 3 resimden 1. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: adım 1, 3 resimden 2. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Internal Assembly: adım 1, 3 resimden 3.
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 2, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 2, 2 resimden 2.
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 3, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 3, 2 resimden 2.
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Motor: adım 4, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Motor Replacement, Motor: adım 4, 2 resimden 2.
    • Use an opening tool to gently pry the ribbon cable away from metal motor chassis.
  5. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 5, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 5, 2 resimden 2.
    • Locate the twisted copper wires feeding from the top of the motor to the upper corner of motherboard.
    • Desolder the contact points.
    • Soldering can cause burns and fires. Always solder in a well-ventilated workspace.
  6. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 6, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 6, 2 resimden 2.
    • Desolder the two connections.
  7. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 7, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 7, 2 resimden 2.
    • Turn the assembly over and remove the Phillips screw.
  8. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 8, 3 resimden 1. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 8, 3 resimden 2. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 8, 3 resimden 3.
    • Pull the motherboard and motor gently away from the motor chassis.
  9. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 9, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Motor Replacement: adım 9, 2 resimden 2.
    • Use a pointed tool to push in the tabs on either side of the white assembly .
    • Pull the wire carrier off of motor chassis.
    • Swap it to the new motor chassis.
Sonuç
Liam Casto
354 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Harley Spring 2024 IUPUI, Team 1-4, Harley Spring 2024 üyesi
IUPUI-HARLEY-S24S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 28
Her zaman: 62
