Ana içeriğe geç
Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement
Neye ihtiyacın var
  1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: adım 1, 3 resimden 1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: adım 1, 3 resimden 2. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Internal Assembly: adım 1, 3 resimden 3.
    • Pry the bottom cap away from the toothbrush body.
    • Pry the bottom cap away from the toothbrush body until it releases.
    • Remove the bottom cap by hand.
  2. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: adım 2, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: adım 2, 2 resimden 2.
    • Use a metal spudger to release the two retaining clips inside the device.
    • The clips release when pried inward.
  3. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: adım 3, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: adım 3, 2 resimden 2.
    • Slide the internal assembly out of the chassis.
  4. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: adım 4, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement, Power Button, Mode Button: adım 4, 2 resimden 2.
    • Locate the power button (solder locations circled in orange).
    • Locate the mode button (solder locations circled in red).
    • Both buttons are attached by four soldered pins each.
  5. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: adım 5, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: adım 5, 2 resimden 2.
    • Heat the soldering iron.
    • Soldering can cause burns and fires. Always solder in a well-ventilated area.
    • To test if the soldering iron is ready, place on the solder and if the solder melts easily and quickly, your soldering iron is ready.
    • Use the soldering iron to desolder all of the connections.
  6. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: adım 6, 2 resimden 1. Philips Sonicare ProtectiveClean 6500 Power Button, Mode Button Replacement: adım 6, 2 resimden 2.
    • Use tweezers to remove the buttons from the board.
    • Place new button onto board and repeat previous steps in reverse to reassemble.
Sonuç
Liam Casto
354 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-4, Harley Spring 2024 IUPUI, Team 1-4, Harley Spring 2024 üyesi
IUPUI-HARLEY-S24S1G4
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 204
