Ana içeriğe geç
Philips Steam Iron GC 1905 Power Cord Replacement
Neye ihtiyacın var
  1. Philips Steam Iron GC 1905 Power Cord Replacement, Power cord replacement: adım 1, 1 resimden 1.
    • Switch off and unplug the iron. Drain the water from the water tank.
    • To prevent damage to the soleplate of the iron, make sure the worktop surface is non-abrasive.
    • Make sure the iron has cooled down before you start disassembly.
  2. Philips Steam Iron GC 1905 Power Cord Replacement: adım 2, 2 resimden 1. Philips Steam Iron GC 1905 Power Cord Replacement: adım 2, 2 resimden 2.
    • Turn over to the triangular backplate of the steam iron.
    • Remove the 10.0 mm screw securing the backplate to the main body with a Phillips #1 screwdriver.
  3. Philips Steam Iron GC 1905 Power Cord Replacement: adım 3, 3 resimden 1. Philips Steam Iron GC 1905 Power Cord Replacement: adım 3, 3 resimden 2. Philips Steam Iron GC 1905 Power Cord Replacement: adım 3, 3 resimden 3.
    • Wedge your thumb and fingers at the joint between the backplate and the handle to loosen the snap joints.
    • Be mindful of the snap joints as they may break if excess pressure is applied.
    • We advise against use of screwdriver to pry open the backplate as it may damage snap joints.
    • Pull out the backplate gently to reveal the electric circuit—it will be still be connected to the wires so don't yank it off.
    • Take a photo of the electrical circuit to use as reference in step 5.
  4. Philips Steam Iron GC 1905 Power Cord Replacement: adım 4, 3 resimden 1. Philips Steam Iron GC 1905 Power Cord Replacement: adım 4, 3 resimden 2. Philips Steam Iron GC 1905 Power Cord Replacement: adım 4, 3 resimden 3.
    • Grip the green cable as close to the crimp connector as possible.
    • For easy removal, pinch the crimp connector between your thumb and forefinger. Apply force to the connector rather than the cable.
    • Slide out the crimp connector attached to the cable.
    • Applying force to the cable might separate the wire from the connector and leave the crimp connector in the slot.
    • Repeat the previous step to remove the red and black cables and take out the power cord.
  5. Philips Steam Iron GC 1905 Power Cord Replacement: adım 5, 3 resimden 1. Philips Steam Iron GC 1905 Power Cord Replacement: adım 5, 3 resimden 2. Philips Steam Iron GC 1905 Power Cord Replacement: adım 5, 3 resimden 3.
    • To connect the new cables, align and slide the crimp connector on the green cable into vacant slot.
    • Repeat the above step for the red and black cables.
    • Make sure the green, red and black cables are inserted in the correct slots.
  6. Philips Steam Iron GC 1905 Power Cord Replacement: adım 6, 1 resimden 1.
    • Before reassembly, ensure that the cord does not obstruct the screw slot.
Sonuç
Happy Fixing!
5 farklı kişi bu kılavuzu tamamladı.
Miraan Dilawari
283 İtibar
1 Kılavuz yazıldı
Ekip
York University, Team 1-5, O'Regan Fall 2021 York University, Team 1-5, O'Regan Fall 2021 üyesi
YORK-O'REGAN-F21S1G5
1 Üye
2 adet Kılavuz yazıldı
2 Yorum
het l'ange deksel was al door mij losgemaakt
2 klips in het midden ...kon niet verder Los krijgen
wat moet ik verser doen zonder stukken te maken stroomdraad is stuk ????
QUISQUATER ETIENNE - Yanıt
But where do I find new wire online
Bharath Reddy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 36
Son 30 gün: 201
Her zaman: 6,844
