Ana içeriğe geç
Philips TAS7505 Battery Replacement
Neye ihtiyacın var
  1. Philips TAS7505 Battery Replacement, Battery: adım 1, 3 resimden 1. Philips TAS7505 Battery Replacement, Battery: adım 1, 3 resimden 2. Philips TAS7505 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the rubber dampener from the bottom of the speaker using your opening tool.
    • However, this will make it harder to replace the rubber dampener, and it may not stick. It is not necessary to the speaker's function.
    FixBot'a Sor
    Yorum Ekle
  2. Philips TAS7505 Battery Replacement: adım 2, 3 resimden 1. Philips TAS7505 Battery Replacement: adım 2, 3 resimden 2. Philips TAS7505 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the four Phillips #0 screws attached to the cover and remove with the opening tool.
    FixBot'a Sor
    Yorum Ekle
  3. Philips TAS7505 Battery Replacement: adım 3, 2 resimden 1. Philips TAS7505 Battery Replacement: adım 3, 2 resimden 2.
    • Remove all Phillips #0 screws to remove the final layers to open the inside.
    FixBot'a Sor
    Yorum Ekle
  4. Philips TAS7505 Battery Replacement: adım 4, 2 resimden 1. Philips TAS7505 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the battery from the motherboard.
    • The cable that connects the battery to the speaker is attached to small pins. You can use your hands to wiggle the battery out.
    FixBot'a Sor
    Yorum Ekle
  5. Philips TAS7505 Battery Replacement: adım 5, 2 resimden 1. Philips TAS7505 Battery Replacement: adım 5, 2 resimden 2.
    • After removing the battery, insert the replacement battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Frederick Jimenez
277 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S5G2
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 58
Her zaman: 1,524
