Ana içeriğe geç
Philips TAS7505 Battery Replacement
Neye ihtiyacın var
  1. Philips TAS7505 Battery Replacement, Battery: adım 1, 3 resimden 1. Philips TAS7505 Battery Replacement, Battery: adım 1, 3 resimden 2. Philips TAS7505 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the rubber dampener from the bottom of the speaker using your opening tool.
    • However, this will make it harder to replace the rubber dampener, and it may not stick. It is not necessary to the speaker's function.
  2. Philips TAS7505 Battery Replacement: adım 2, 3 resimden 1. Philips TAS7505 Battery Replacement: adım 2, 3 resimden 2. Philips TAS7505 Battery Replacement: adım 2, 3 resimden 3.
    • Remove the four Phillips #0 screws attached to the cover and remove with the opening tool.
  3. Philips TAS7505 Battery Replacement: adım 3, 2 resimden 1. Philips TAS7505 Battery Replacement: adım 3, 2 resimden 2.
    • Remove all Phillips #0 screws to remove the final layers to open the inside.
  4. Philips TAS7505 Battery Replacement: adım 4, 2 resimden 1. Philips TAS7505 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the battery from the motherboard.
    • The cable that connects the battery to the speaker is attached to small pins. You can use your hands to wiggle the battery out.
  5. Philips TAS7505 Battery Replacement: adım 5, 2 resimden 1. Philips TAS7505 Battery Replacement: adım 5, 2 resimden 2.
    • After removing the battery, insert the replacement battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Frederick Jimenez
277 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S5G2
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 630
