Ana içeriğe geç
Philips TAS7505 Motherboard Replacement
Neye ihtiyacın var
  1. Philips TAS7505 Motherboard Replacement, Philips TAS7505 Outer Shell Disassembly: adım 1, 2 resimden 1. Philips TAS7505 Motherboard Replacement, Philips TAS7505 Outer Shell Disassembly: adım 1, 2 resimden 2.
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
    FixBot'a Sor
    Yorum Ekle
  2. Philips TAS7505 Motherboard Replacement: adım 2, 3 resimden 1. Philips TAS7505 Motherboard Replacement: adım 2, 3 resimden 2. Philips TAS7505 Motherboard Replacement: adım 2, 3 resimden 3.
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
    FixBot'a Sor
    Yorum Ekle
  3. Philips TAS7505 Motherboard Replacement: adım 3, 3 resimden 1. Philips TAS7505 Motherboard Replacement: adım 3, 3 resimden 2. Philips TAS7505 Motherboard Replacement: adım 3, 3 resimden 3.
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
    FixBot'a Sor
    Yorum Ekle
  4. Philips TAS7505 Motherboard Replacement: adım 4, 3 resimden 1. Philips TAS7505 Motherboard Replacement: adım 4, 3 resimden 2. Philips TAS7505 Motherboard Replacement: adım 4, 3 resimden 3.
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
    FixBot'a Sor
    Yorum Ekle
  5. Philips TAS7505 Motherboard Replacement: adım 5, 1 resimden 1.
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
    FixBot'a Sor
    Yorum Ekle
  6. Philips TAS7505 Motherboard Replacement, Motherboard: adım 6, 3 resimden 1. Philips TAS7505 Motherboard Replacement, Motherboard: adım 6, 3 resimden 2. Philips TAS7505 Motherboard Replacement, Motherboard: adım 6, 3 resimden 3.
    • Disconnect the battery from the motherboard by unclipping it from the side not visible to you
    • If you are having difficulties disconnecting the battery you can pull the battery out whole in order to get a better angle to disconnect it
    FixBot'a Sor
    Yorum Ekle
  7. Philips TAS7505 Motherboard Replacement: adım 7, 1 resimden 1.
    • Pull out the motherboard then disconnect the USB-A & USB-C port by pressing the clip
    FixBot'a Sor
    Yorum Ekle
  8. Philips TAS7505 Motherboard Replacement: adım 8, 2 resimden 1. Philips TAS7505 Motherboard Replacement: adım 8, 2 resimden 2.
    • Next is to disconnect the speaker
    • pull the motherboard out as much as you can and then wiggle the white box back and forth to get it out
    FixBot'a Sor
    Yorum Ekle
  9. Philips TAS7505 Motherboard Replacement: adım 9, 2 resimden 1. Philips TAS7505 Motherboard Replacement: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Simply remove this white strand with a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  10. Philips TAS7505 Motherboard Replacement: adım 10, 2 resimden 1. Philips TAS7505 Motherboard Replacement: adım 10, 2 resimden 2.
    • This is how the motherboard should be after doing all the steps correctly.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Alejandro
133 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S5G2
5 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
The guides are very detailed with many steps and are easy to follow. It looks professional and well-made. Thank you for your contribution to Ifixit!
Dat Nguyen - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 44
Her zaman: 809
