Ana içeriğe geç
Philips TAS7505 Speaker Replacement
Neye ihtiyacın var
  1. Philips TAS7505 Speaker Replacement, Speaker: adım 1, 3 resimden 1. Philips TAS7505 Speaker Replacement, Speaker: adım 1, 3 resimden 2. Philips TAS7505 Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Using the opening tool, remove the rubber padding from the bottom of the speaker.
    • The rubber padding is glued on and may require reapplying adhesive to re-assemble.
  2. Philips TAS7505 Speaker Replacement: adım 2, 3 resimden 1. Philips TAS7505 Speaker Replacement: adım 2, 3 resimden 2. Philips TAS7505 Speaker Replacement: adım 2, 3 resimden 3.
    • Using the Philips screwdriver head #0, remove all four screws holding the plastic plate in place.
    • Use the same opening tool from the previous step to remove the plastic plate.
  3. Philips TAS7505 Speaker Replacement: adım 3, 3 resimden 1. Philips TAS7505 Speaker Replacement: adım 3, 3 resimden 2. Philips TAS7505 Speaker Replacement: adım 3, 3 resimden 3.
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with the Philips 0-bit screwdriver bit.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 Speaker Replacement: adım 4, 3 resimden 1. Philips TAS7505 Speaker Replacement: adım 4, 3 resimden 2. Philips TAS7505 Speaker Replacement: adım 4, 3 resimden 3.
    • Squeeze the white connector on the bottom to release a clip that is hidden from sight. This will allow it to be wiggled free.
    • Remove the battery from the speaker by disconnecting the white connector from the motherboard.
  5. Philips TAS7505 Speaker Replacement: adım 5, 3 resimden 1. Philips TAS7505 Speaker Replacement: adım 5, 3 resimden 2. Philips TAS7505 Speaker Replacement: adım 5, 3 resimden 3.
    • Find the rubber flap that covers the USB-A and USB-C port
    • Pull on the rubber flap, it should come out whole as shown in the second image
    • Once taken out the rubber flap, pull the interior of the speaker
  6. Philips TAS7505 Speaker Replacement: adım 6, 2 resimden 1. Philips TAS7505 Speaker Replacement: adım 6, 2 resimden 2.
    • Once you have the speaker body out, unscrew the four screws holding the speaker down
    • Use Philips screwdriver head #0
  7. Philips TAS7505 Speaker Replacement: adım 7, 1 resimden 1.
    • Pull the motherboard out then disconnect the white connector of the speaker by wiggling it back and forth.
    • See the motherboard repair guide for more in-depth instructions on this part
  8. Philips TAS7505 Speaker Replacement: adım 8, 3 resimden 1. Philips TAS7505 Speaker Replacement: adım 8, 3 resimden 2. Philips TAS7505 Speaker Replacement: adım 8, 3 resimden 3.
    • The speaker will look like this if you have followed the steps correctly
Sonuç
Frederick Jimenez
277 İtibar
2 adet Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S5G2
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 40
Her zaman: 590
