Ana içeriğe geç
Philips TAS7505 USB-A & USB-C port Replacement
Neye ihtiyacın var
  1. Philips TAS7505 USB-A & USB-C port Replacement, Philips TAS7505 Outer Shell Disassembly: adım 1, 2 resimden 1. Philips TAS7505 USB-A & USB-C port Replacement, Philips TAS7505 Outer Shell Disassembly: adım 1, 2 resimden 2.
    • Make sure the speaker is turned off before you begin the disassembly.
    • Turn the speaker upside down. You will see a rubber base. Use an opening tool to lift up the sides to expose the screws.
  2. Philips TAS7505 USB-A & USB-C port Replacement: adım 2, 3 resimden 1. Philips TAS7505 USB-A & USB-C port Replacement: adım 2, 3 resimden 2. Philips TAS7505 USB-A & USB-C port Replacement: adım 2, 3 resimden 3.
    • There will be 4 exposed screws. Make sure to use the Phillips #0 Screwdriver.
    • When the screws are removed, you can use an opening tool to take off the plastic cover.
  3. Philips TAS7505 USB-A & USB-C port Replacement: adım 3, 3 resimden 1. Philips TAS7505 USB-A & USB-C port Replacement: adım 3, 3 resimden 2. Philips TAS7505 USB-A & USB-C port Replacement: adım 3, 3 resimden 3.
    • Now that you have removed this cover, there is another cover. This cover has a total of 9 screws that can be removed with a Philips #0 screwdriver.
    • Once all these screws are removed, you can take off the cover
  4. Philips TAS7505 USB-A & USB-C port Replacement: adım 4, 3 resimden 1. Philips TAS7505 USB-A & USB-C port Replacement: adım 4, 3 resimden 2. Philips TAS7505 USB-A & USB-C port Replacement: adım 4, 3 resimden 3.
    • You can now see the inside of the speaker but you aren't done yet.
    • Remove both rubber stands that hold up the device horizontally (one of these stands is a cover for the USB ports).
  5. Philips TAS7505 USB-A & USB-C port Replacement: adım 5, 1 resimden 1.
    • Once you pull these out, you can pull the whole sleeve to expose the infrastructure of the device.
  6. Philips TAS7505 USB-A & USB-C port Replacement, USB-A & USB-C port: adım 6, 1 resimden 1.
    • Use the Phillips #0 Screwdriver to remove all 6 screws.
  7. Philips TAS7505 USB-A & USB-C port Replacement: adım 7, 1 resimden 1.
    • Before pulling the USB port box out, disconnected the power connector from the motherboard.
    • Carefully pull out the USB port box
Sonuç
Yamilena Hernandez
135 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 5-2, Adachi Fall 2022 CSU Los Angeles, Team 5-2, Adachi Fall 2022 üyesi
CSULA-ADACHI-F22S5G2
5 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 24
Her zaman: 342
