Ana içeriğe geç
Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement
Neye ihtiyacın var
  1. Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement, On / Off switch exchange: adım 1, 2 resimden 1. Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement, On / Off switch exchange: adım 1, 2 resimden 2.
    • First remove the white side parts with a thin slotted screwdriver (everything is just "clipped")
  2. Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement: adım 2, 3 resimden 1. Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement: adım 2, 3 resimden 2. Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement: adım 2, 3 resimden 3.
    • Next, open the black plastic case (also like the white parts with a thin slotted screwdriver)
  3. Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement: adım 3, 2 resimden 1. Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement: adım 3, 2 resimden 2.
    • The capsule has on the outside only 5/6 points where the upper and lower shell are connected.
    • Next, the "waterproof capsule" must be removed and opened.
  4. Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement: adım 4, 2 resimden 1. Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement: adım 4, 2 resimden 2.
    • Now, when the capsule is open, you can already see the "culprit" (The small button to the right of the large IC chip)
    • Now carefully desolder this button
  5. Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement: adım 5, 2 resimden 1. Philips TT2021 Bodygroomer Series 5000 On / Off Switch Replacement: adım 5, 2 resimden 2.
    • Now solder in the new button
    • The button should rest on the IC module so as not to slip / bend
Sonuç
Repeat the steps in order to reassemble your device.
Bir başkası bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Israel dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
bper
137 İtibar
1 Kılavuz yazıldı
Bir Yorum
Die länglichen Löcher in der Platine erfordern dabei kein Zuschneiden der Anschlüsse der Akkus. Alles wieder zusammengebaut und den Einschalter betätigt. Ein paar Sekunden lang blinkt die LED und nichts passiert. Unverständlich warum! Der Rasier ging ja vor der Reparatur - nur halt nur noch wenige Minuten. Kann doch nicht defekt sein.
Nach langem Suchen kam ich auf die Idee es mit Aufladen zu probieren, obwohl ich die Akkus vor dem Einbau voll geladen hatte. Und schon ein paar Sekunden Laden reichten und der Bodygroom läuft!
Der Trick: Philips hat eine Schutzschaltung eingebaut, die Tiefentladung verhindern soll. Erkennt der Rasierer einmal, dass er leer ist, schaltet er dauerhaft ab und kann auch nach längerer Wartezeit nicht mehr für ein paar Minuten genutzt werden. Diesen "Leerzustand" merkt sich der Bodygroom auch beim Wechsel des Akkus. Durch kurzen Kontakt mit Ladestrom wird die Sperre gelöst und das Gerät arbeitet wieder.
Klaus Minhardt - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 19
Her zaman: 3,282
