Giriş
If the battery for your Photive Hydra is not holding a charge, or if it does not charge at all, it may need to be replaced. If you plan on replacing the battery you will need a replacement battery on hand. The battery that this device uses is a ICR18650 -26H.
Neye ihtiyacın var
Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
Bir başkası bu kılavuzu tamamladı.
