Ana içeriğe geç
Picture Frame Matting Replacement
Neye ihtiyacın var
  1. Picture Frame Matting Replacement, Picture Frame Matting: adım 1, 1 resimden 1.
    • Place the picture frame face down on a clean surface.
  2. Picture Frame Matting Replacement: adım 2, 1 resimden 1.
    • Use a spudger to rotate all of the frame’s backing clips away from the frame.
  3. Picture Frame Matting Replacement: adım 3, 2 resimden 1. Picture Frame Matting Replacement: adım 3, 2 resimden 2.
    • Remove the backing by lifting it up and away using a spudger.
  4. Picture Frame Matting Replacement: adım 4, 1 resimden 1.
    • Carefully remove the picture and old matting from the frame.
    • You can leave the glass in the frame.
  5. Picture Frame Matting Replacement: adım 5, 1 resimden 1.
    • Place the new matting into the frame and directly onto the glass.
    • Be careful while working around the glass to avoid self-injury or damaging the item.
  6. Picture Frame Matting Replacement: adım 6, 2 resimden 1. Picture Frame Matting Replacement: adım 6, 2 resimden 2.
    • Position the picture properly and place it on the new matting.
    • Make sure there are no gaps between the edge of the picture and the matting.
    • Carefully place a couple of small pieces of clear tape on the picture and the new matting to hold it in place.
  7. Picture Frame Matting Replacement: adım 7, 1 resimden 1.
    • Place the backing on top of the matting in the frame.
  8. Picture Frame Matting Replacement: adım 8, 2 resimden 1. Picture Frame Matting Replacement: adım 8, 2 resimden 2.
    • Rotate the backing clips under the frame to secure it.
Bitiş Çizgisi
Leah
160 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 177
