Ana içeriğe geç
Pioneer A1 XW-SMA1-K Motherboard Replacement
Neye ihtiyacın var
  1. Pioneer A1 XW-SMA1-K Motherboard Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use the spudger to remove the mesh front panel.
  2. Pioneer A1 XW-SMA1-K Motherboard Replacement: adım 2, 2 resimden 1. Pioneer A1 XW-SMA1-K Motherboard Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #1 screwdriver to remove the thirteen 12 mm screws in the speaker frame.
    • Remove the speaker frame by pulling vertically upwards revealing the motherboard.
  3. Pioneer A1 XW-SMA1-K Motherboard Replacement: adım 3, 3 resimden 1. Pioneer A1 XW-SMA1-K Motherboard Replacement: adım 3, 3 resimden 2. Pioneer A1 XW-SMA1-K Motherboard Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the twelve 12 mm screws from the middle frame.
    • Remove the middle frame by pulling upward and vertically.
  4. Pioneer A1 XW-SMA1-K Motherboard Replacement: adım 4, 2 resimden 1. Pioneer A1 XW-SMA1-K Motherboard Replacement: adım 4, 2 resimden 2.
    • Use the Phillips #1 screwdriver to remove the nine 12 mm screws from the motherboard.
    • Flip the motherboard over.
    • Remove the motherboard by detaching the antenna.
  5. Pioneer A1 XW-SMA1-K Motherboard Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the motherboard from the speaker.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 18
Her zaman: 578
