Ana içeriğe geç
Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement
Neye ihtiyacın var
  1. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement, Control Panel Circuit Board: adım 1, 1 resimden 1.
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: adım 2, 1 resimden 1.
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
  3. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: adım 3, 1 resimden 1.
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: adım 4, 1 resimden 1.
    • Unlatch the three plastic connectors on the top of the receiver that hold the front panel to the device casing.
  5. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: adım 5, 1 resimden 1.
    • The connectors on the bottom of the device may be very stiff and could require the use of a plastic prying tool.
    • Carefully flip the device over and unlatch the three plastic connectors that hold the front panel to the bottom of the device casing.
  6. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: adım 6, 1 resimden 1.
    • Grip and unplug the ribbon connector that connects the front circuit board to the device.
  7. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: adım 7, 1 resimden 1.
    • Unscrew the three 1/4 Phillips head screws on the back of the front circuit board.
  8. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: adım 8, 2 resimden 1. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: adım 8, 2 resimden 2.
    • Grip the circuit board and slide towards the front side of the plastic casing.
    • Lift upwards to remove the circuit board from the front panel.
Sonuç
Cody Carter
1.049 İtibar
6 adet Kılavuz yazıldı
Ekip
Baylor, Team S1-G5, Johnson Spring 2018 Baylor, Team S1-G5, Johnson Spring 2018 üyesi
BU-JOHNSON-S18S1G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 461
