Giriş
The Smart Speaker has a back panel where the speaker's jacks and other ports are located. The panel is replaced as a unit. To access the box, we are going to need to take apart the entire inside of the speaker. Please note that replacing this part requires the speakers casing to be damaged.
Neye ihtiyacın var
Flip the speaker upside down with the back panel of plugs pointed away from you.
Peel off all rubber strips along sides, middle front and middle back of the device.
Using the metal spudger, peel the backing off of the back panel of the speaker to reveal 4 screw holes.
