Ana içeriğe geç
Pioneer FH-X730BS Disk Drive Replacement
Neye ihtiyacın var
  1. Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: adım 1, 3 resimden 1. Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: adım 1, 3 resimden 2. Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: adım 1, 3 resimden 3.
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS Disk Drive Replacement: adım 2, 1 resimden 1.
    • After removing the stereo face from the frame, it should look similar to this.
  3. Pioneer FH-X730BS Disk Drive Replacement: adım 3, 1 resimden 1.
    • Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
  4. Pioneer FH-X730BS Disk Drive Replacement: adım 4, 3 resimden 1. Pioneer FH-X730BS Disk Drive Replacement: adım 4, 3 resimden 2. Pioneer FH-X730BS Disk Drive Replacement: adım 4, 3 resimden 3.
    • Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
  5. Pioneer FH-X730BS Disk Drive Replacement: adım 5, 3 resimden 1. Pioneer FH-X730BS Disk Drive Replacement: adım 5, 3 resimden 2. Pioneer FH-X730BS Disk Drive Replacement: adım 5, 3 resimden 3.
    • Unscrew the four inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate.
    • Replace the old disk drive with a new one.
Sonuç
Cody Pesta
688 İtibar
6 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 307
