Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Apply pressure to the tabs on each side using the plastic opening tool.
You will need to pull the face away from the frame while unhooking the tabs.
After removing the stereo face from the frame, it should look similar to this.
Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
Unscrew the four inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate.
Replace the old disk drive with a new one.
