Ana içeriğe geç
Pioneer FH-X730BS USB Port Replacement
Neye ihtiyacın var
  1. Pioneer FH-X730BS USB Port Replacement, Deck Buttons: adım 1, 3 resimden 1. Pioneer FH-X730BS USB Port Replacement, Deck Buttons: adım 1, 3 resimden 2. Pioneer FH-X730BS USB Port Replacement, Deck Buttons: adım 1, 3 resimden 3.
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS USB Port Replacement: adım 2, 3 resimden 1. Pioneer FH-X730BS USB Port Replacement: adım 2, 3 resimden 2. Pioneer FH-X730BS USB Port Replacement: adım 2, 3 resimden 3.
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Pioneer FH-X730BS USB Port Replacement: adım 3, 3 resimden 1. Pioneer FH-X730BS USB Port Replacement: adım 3, 3 resimden 2. Pioneer FH-X730BS USB Port Replacement: adım 3, 3 resimden 3.
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  4. Pioneer FH-X730BS USB Port Replacement, USB Port: adım 4, 1 resimden 1.
    • Here you are able to desolder the USB ports from the circuit board and solder a replacement USB port on.
    • The end of the soldering iron will be hot.
Sonuç
Cody Pesta
688 İtibar
6 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 1,142
