Ana içeriğe geç
Pioneer MXT-X366BT Metal Case Replacement
Neye ihtiyacın var
  1. Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: adım 1, 2 resimden 1. Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: adım 1, 2 resimden 2.
    • Apply small amount of pressure inward with a plastic opening tool to release bottom clip.
    • Pry the top clip with the plastic opening tool to release it.
    • The head unit is symmetrical and has the same amount of clips on the other side.
  2. Pioneer MXT-X366BT Metal Case Replacement: adım 2, 1 resimden 1.
    • Remove the face plate holder.
  3. Pioneer MXT-X366BT Metal Case Replacement: adım 3, 1 resimden 1.
    • Remove the six 5mm Phillips-head screws with Philips #2 screwdriver.
  4. Pioneer MXT-X366BT Metal Case Replacement: adım 4, 2 resimden 1. Pioneer MXT-X366BT Metal Case Replacement: adım 4, 2 resimden 2.
    • Remove the inner three 5mm Phillips head screws, with a Phillips #2 screwdriver, attached to the metal backing.
    • Remove the metal backing that is now free.
  5. Pioneer MXT-X366BT Metal Case Replacement: adım 5, 1 resimden 1.
    • Carefully slide the metal casing forward.
    • Metal piece standing is the rear of the head unit.
    • Edges are sharp.
  6. Pioneer MXT-X366BT Metal Case Replacement: adım 6, 1 resimden 1.
    • Lift the metal casing from the rear and pull it away.
    • Edges are sharp.
  7. Pioneer MXT-X366BT Metal Case Replacement: adım 7, 1 resimden 1.
    • The metal casing is now fully removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Blaine Kaiser
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 301
